How would I put the second audio track on a VCD mpeg? The problem is: I need commentary for a video I made. And was wondering if it was possible to have it so that when you push the audio button on the DVD remote, it switches over to an alternate audio track.
Oh, and is anyone else having a problem when using "mAC3dec 1.5.1" to convert audio?
thanks
"First god damn week of winter." --R.J. MacReady
No, the only way that it has been done is a stereo track where left is one channel and right is another.
Well the vcd standard supports 1 stereo or 2 mono tracks so you could still keep the two audio tracks separate as long as they are both mono. Just use TMPGenc or bbmpeg to multiplex but not all standalone dvd players will properly play these back.
I use this same idea for Svcds whenever the dvd has two audio commentaries, since SVCDS support 2 stereo or up to 4 mono tracks. I use 1 stereo track for the main audio and 2 mono tracks, one for each commentary. I can toggle between each of these tracks on my Apex AD600a. The only way I have found to multiplex 3 separate audio streams into a SVCD compliant program stream is with TMPGenc. -
The mplex function in MMT has supported second stereo audio track since June. homepage.mac.com/rnc
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
