when I load an .avi file in VirtualDub, it says audio is VBR, need to export the entire WAV and recompress it with a constant bitrate encoder.......where can I get one, and which are good?
What do you wanna do with your avi file, playing in your computer only or you wanna convert to vcd/svcd in order to play in your stand alone?
If you want just to watch avi file on computer you don't need wav file but if you want to convert with TMPGenc, yes absolutely you want to create wave file from avi file.
In V-dub at Audio Tab select Full Processing Mode, then choose " Save wav" under file tab. Now you got one big wav file and use that for Audio Source in TMPGenc.
This method sometime help "out of sync issure" after converting avi to mpeg as well. -
Hi jovianrich
As ya_jai says use Virtual dub. It has the "decompresser" built in. Do as ya_jai told you, but remember to set compression to no compression(PCM) before you save the wav file.
Here is a very short step by step guide. All done in virtual dub
Open your avi file. Choose audio, full processing mode. Choose audio again, choose compression, and choose no compression (PCM).
Choose file, choose save wav.
Thats it, you now have an uncompressed wav file with the sound.Best regards
Jens Gervil
MKV Recompression
By JordanConley in forum Video ConversionReplies: 5Last Post: 19th Jul 2011, 01:40 -
Avoiding YouTube Recompression
By roflwaffle in forum Video Streaming DownloadingReplies: 3Last Post: 26th Sep 2010, 06:22 -
How to Edit with VD without recompression
By unkown in forum EditingReplies: 13Last Post: 26th Aug 2007, 08:34 -
Resizing Without Recompression.
By Rez. in forum DVB / IPTVReplies: 8Last Post: 2nd Aug 2007, 12:17 -
Merge 2 identical format AVIs, no recompression, audio de-synced on 2nd 1/2
By BilboFett in forum EditingReplies: 2Last Post: 13th May 2007, 21:54
