I have been having some audio/sync problems in vcds recently. I convert the .avi or vobs to .mpg and then burn them to vcd.
I use (from vobs) :
Smartripper
Dvd2avi (frameserve)
Tmpgenc (standard compliance vcd template)
After I've burnt the mpgs to vcd they are in sync via my computer's dvd drive but when I play them via my standalone dvd player (limit dvd8072) the audio is out of sync. This also happens with pre-made .mpgs that are downloaded.
My cd-rw is a 4x teac cd-w54E, and the cd's I use are up to 8x compatibile.
Any help would be much appericated.
I always extract the audio from the avi file with Virtualdub before encoding with Tmpgenc.
1. Launch Virtualdub
2. Load avi file
3. Select Audio --- Full Processing Mode
3. Select Audio --- Compression --- no compression PCM
4. Select Audio --- Conversion --- convert to 44100 Hz
5. Select File --- Save WAV
Then I launch Tmpgenc and select the avi file as video input and the wav file as audio input.
Alejandro. -
Thanks for the response but I've already tried that and it didn't help. I really am just stumped at whats wrong.
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 22:28
