ive just started authoring my own vcds from divx files and while watching them on my dvd player ive noticed that the video will lag for a while while the sound keeps on going, then the video will speed up and catch up with the sound.
another possibly related problem is ive been having some "Buffer Underrun" errors, which i have no idea what they are or how to fix this, any suggestions or quick fixes??
if your movies are encoded with divx 5 that could be the problem,i notice my divx 5 movies do that,if so try a fast recompress to divx 3 or 4 then convert.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 14:36 -
strange buzz in audio/subs out of sync
By mique in forum ffmpegX general discussionReplies: 1Last Post: 11th Oct 2007, 19:46 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
