whats up with every movie i convert to dvd mpeg..... and try to add menu or scene to the movie that it add extra gb's of info to the file size:::: for example i just converted a movie to dvd using tmpegnc and it came out to 3.3gb but when i put it in thru m.f. it says it needs 7gb of space.... is there a setting or something that i need to set... i no menus dont take up that much space for shhhhhit......
Relax, about half of the 7gb is for temporary space needed to create the finished vob files before burning. You do need to have more then 7gb available of free space and be sure to defragment the hard drive for best results.
After completing your project check for an MPG file that was created by DVDMF before it creates the vob files. (DVDMF may delete this upon completion of the project so you may not find it) -
thanks..... but is it anyway around that.... because sometime i dont have the room on my machine.....
Where to download menu templates - Corel DVD MovieFactory 7
By Roundabout in forum Authoring (DVD)Replies: 4Last Post: 13th Feb 2011, 17:59 -
audio glitches
By sandiegoguy in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2009, 15:24 -
Audio Playback glitches
By cmccarty82 in forum Authoring (DVD)Replies: 3Last Post: 13th Jul 2009, 14:07 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 01:59
