please anyone - where can i get an accurate mpeg1/2 bitrate calc for STANDARD vcd/svcd?
ive got many, but non of which are accurate - my vcds get sometimes bigger, while in others ive lost quality cause some prog gave wrong b/rate
grrr what am i doing wrong?
after calculating it manually - TMPGENC still got a different sizes- for ex. a 25min video - encoded with default ntsc svcd got a 490megs file - thus when calculated its like a 50megs less......
any help?
thankx
DVDx seems to give an accurate calculation of file size. Also, as it encodes it will split your mpg into 800Mb chunks (or whatever size you want).
There are other things that can increase filesize besides your bitrate, such as multiplexing overhead and even authoring overhead.
Try FitCD. It is the absolute most accurate bitrate calculator there is because it accounts for just about every little thing that could effect your filesize.
I don't understand why you need a bitrate calculator for a standard vcd since the bitrate is set at 1150k. I assume you meant xvcd?
Desperately seeking R2D2 region hack!
By Purpleyez in forum DVD & Blu-ray PlayersReplies: 18Last Post: 3rd Jan 2013, 05:44 -
Desperately seeking this Mac feature in a Windows app
By sheslostcontrol in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Nov 2009, 07:57 -
Microsoft desperately seeking the Magnificent Seven
By ahhaa in forum ComputerReplies: 3Last Post: 14th Feb 2009, 10:09 -
Desperately Seeking Help! Home Theatre problem
By jbsbubby in forum Newbie / General discussionsReplies: 12Last Post: 4th Jan 2009, 22:08 -
Bitrate Calc Question
By cquetsch in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2007, 19:11
