Can you join and cut DivX avi files before encoding to mpg ? and if so what is the best way of doing it ? I've got a 2 disc DivX and want to split into 3 parts before encoding.
Panther
All say Grrrrrrrrrr...................... -
use virtual dub-
http://www.vcdhelp.com/virtualdubedit.htmWhere I walk, I walk alone. Where I fight, I fight alone. -
Sure you can. Very easy. Use a newer version of vdub
Open VirtualDub
Select under BOTH Audio and Video - Direct Stream Copy
1. Open the file
2. go to file - append video
3. open the second clip
4. go to file - append video
5. open the third clip
6. repeat if necessary
Last save the the new clip with File->Save as AVI
or you can use Sonic Foundry Vegas Video or Premiere, load up all your clips, back to back, but then you'd have to render them back out again - Vdub is a quick easy copy providing they're all the same sampling, etc....~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Only if the sizes and framerate are identical.
Hello.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 13:01 -
How do I joing 2 files
By wan2no in forum ComputerReplies: 4Last Post: 16th May 2008, 23:46 -
Joing two dvds?
By Castor troy in forum DVD RippingReplies: 1Last Post: 10th Feb 2008, 17:21 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 12:28
