  1. Hi.
    When I try to convert my divx movies to svcd I use tmpenc and eveything is working fine. But when I play my svcd in my standalone dvd-player the picture is sometimes freezing but after a couple of seconds everything is back to normal. What can be wrong? I usually frame serve with virtualdub to get the subs. Does tmpgenc misses to render som frames so it freezes or what?
    I would appreciate answers.
    /tomas
  2. what frame rate are you using to convert?? 23.976 or 29.97???
  3. the source is 23.976 fps som I am using ntsc film, isnt that correct?
  4. Sounds like it could be a stand-alone problem, what are you using?
  5. I use mustek dvd v560
  6. From the comments on the DVD compatability list, your player should handle S/VCDs with no problems.. perhaps its the media you are using?
  7. Have you tried to play that Divx in your computer and see if it does the same thing? It might be your Divx file. Try using Divfix to rebuild index; but beware after you used dvifix you can't go back to the original file, so my suggestion is, use a copy file instead. Hope this help.
