Well, the subject says it all.
I canīt rewind or fast forward my svcds on my standalone dvd player.
It is fairly annoying.
Is it because of my dvd player or could there be another reason?
Thankful for an answer
Regards
Nille
what burning software are you using and the version number of that software?
don't hang your dirty laundry in public -
No, the subject didn't say it all. You need to give some more details such as what burnning software. My best guess is you was using NERO to burn your SVCD, and if i'm right, you need to go with some other way. To create bin/cue file with VCDimager is one way to help you solve this problem. you can search some more on this fast forward issue, it's been in this forum for a long long long time.
i have this problem with some of my svcd's found out it was my phillips dvd causing the problem
I have found all dvd players are not equal I went thru 3 new players before I found one that would fast forward svcds I ended up with a Sansui
Before I burnt with NERO and I cant fast forward SVCD in my player. Then I use VCDImager and that problem was gone. So I don't think it's only a player thing, thou.
when using older version's of nero you have to download a file and copy and paste it. This is explained more in the author guides. For svcd's the file that has to be downloaded is scandata.dat here's the link to the guide for burning svcd's with nero http://www.vcdhelp.com/nerosvcd.htm It will also provide you with the download for the scandata.dat file.
im using a later version of ner, but iīve now tried with with vcd easy and that solved the problem.
Thanks for your help.
Regards
peter
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 07:16 -
Sumvision Phoenix will only fast forward or rewind some files.
By muay in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2011, 08:01 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 16:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 28th Jun 2008, 00:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 22:48
