  1. I am having really bad issues with my moviestar software that came with the dazzle II card. The software is giving me an error about not being able to read the memory and then the software will not launch. I have tried reinstalling the software after uninstalling it but it will not launch the program.
    I was wanting to know if there were some other software options that I can use to capture with....I am aware of TWNH but that is the only other software that I know of.
    thanks!
    Apr 2002
    The State of Frustration
    This guide was written by a fellow Dazzle Card owner:
    http://www.vcdhelp.com/dazzlecapture.htm
    Hello.
  3. thanks, but this guide references the software that is not functioning on my PC. I have tried everything I can think of to get Moviestar 4.24 to work on my PC, but it is not happening. I was wanting to know what other software options are available for capturing.
    thanks!
    Apr 2002
    You can capture with Virtual Dub.
    Hello.
  5. I have tried with virtualdub with no success. it sees the dazzlecard but I get an error that states that the video device is already in use. I have looked on my device mgr but no applications are in use at this time. Does anyone have any ideas?
  6. Originally Posted by Tommyknocker
    not with the DVCII
  7. I have also tried a program called Bugsy with a C++ runtime error. I am becoming very discouraged.....
  8. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Try here http://www.spawns.dk/svcd/Index.htm
    check the forums out too.
