Thanks to everyone who helped by submitting bug reports to me.
you can now download the new version from http://www.eazyvcd.tk
If anyone could help me out with a file mirror please e-mail me(dick_p_t@hotmail.com)
Relese Information
Version 1.01
- added Audio Track selection
- now frame serves with DVD2AVI
- nolonger uses MPEG2 plug-in so video encodeing speed has incresed and it better quality
- removed need for DOS batch files
- wrote BatchCreator into the exe for smother running
- now rips to standard vob file size so you can use on a FAT/FAt32 Drive
- Can now use spaces in file name and path
- Put in more error handlers
- Installer now installs an ASPI Layer
Knowen Bugs
- If you close Eazy VCD before it has finished, it will still run in the background
- the first time you use Eazy VCD and it get's up to the TMPGEnc Encodeing stage, TMPGEnc will show you a Splash screen, you must select the "Don't show this dialog again at startup" check box and then click ok. You will never see it again.
Results 1 to 9 of 9
DVD to VCD made eazy
http://www.eazyvcd.tk -
by the way, i downloaded this the other day. looks great. and i would love to use it if i can only fix the problem in my thread...
Just out of curiousity, can the ASPI installation portion be overridden? My ASPI is working fine, and I really don't want to mess with it
But, I'd like to try the program.
HDC -
I have now made 3 vcd's with this and it is absolutely excellent. Well done on a great job. The only thing I wondered is can you add a bit to control the MPEG Tools section of TMPGEnc so that you would just put in the type of CDR (e.g. 80min) that you are burning to and it then cuts the mpeg for you as part of the automated process?
Chris
:P -
automatic cutting will be included in a future relese, but not for a while yet (probly about a month or more) as i am busy trying to get it so you can select which program chain you want to rip off the dvd and also make "Eazy VCD" automaticly display the names of the audio streams so you can select a different language with ease.
anyhow, I'm glad you like the software, and thanks for your comments.DVD to VCD made eazy
Hi again!
Just a question for dick_p_t!
I've already said what an excellent program this is! I was using CladXP before, but found that the picture was jerky and robotic, also when i was encoding AVI's, using Eazy VCD, there is no jerkiness!
My question is, how do i stop the jerkiness? Obviously it is something to do with the settings, and you've got them configured correctly, so could you let me know what settings you set TMPEGenc at please!
Any advice is mucho appreciated, and keep up the good work! Looking forward to new edition! 8) -
The settings are the same as the VCD (PAL) and VCD (NTSC) templates.
The only thing that is changed is the 'sorce aspect ratio' and the 'Motion Search Speed' that you set in "Eazy VCD"DVD to VCD made eazy
I've been putting it in "normal" or "high quality", is this wrong, and what source ratio do you use?
TMPGEnc uses what ever you set "Aspect Ratio" to in "Eazy VCD"
and same with "Motion Search Speed".DVD to VCD made eazy
how do i download these??
By XBucklawX in forum Video Streaming DownloadingReplies: 1Last Post: 18th Jan 2009, 21:25 -
where to download DVD/ VCD covers and labels?
By pglenn in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 04:36 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 01:29
