I have install the newest AIW Radeon driver and VirtualDub before I attempt to capture using VirtualDub with Lossless compression drivers.
Anyway, I'm in US, so I choose the format to be 29.97 FPS and NTSC_M. However, I was not able to choose 352X240, only 352X288 was available. So I use set Custom format.
In any cases, it still didn't work, because it still capture the video at 352X288, and since signal is 352X240, it added the letter box on the top and bottom.
My question is that how do I set it to 352X240 so I can get rid of the letter box? I have tried everything, even Sonic Foundry's Video Capture.
In Sonic Foundry, I was able to select 352X240 from one of the capture driver setting, BUT.... when I capture it, it is still 352X288 with letter box, and not only that, when I went back to the selection, it was on 352X288, no matter how many time I select on the 352X240, it still capture at 352X288.
Could this be a capture driver problem?
Thanks.
Results 1 to 1 of 1
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 01:03 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
