I am using FFMPEG 0.4.5 to convert DivX to MPEG1. The video in the files produced is choppy, and there are occasionally random squeaking noises in the sound. Any suggestions as to how to correct this woudl be greatly appreciated.
Regards,
Randolph Carter
What options do you use ?
I'm trying to get ffmpeg to convert some of my Divx movies to VCD, and the options that I use are:
ffmpeg -vcd -i INPUT.AVI -b 1150 -s 352X288 -r 23.967 -vcodec mpeg1video -f mpegvideo ready_2_go.mp
The INPUT.AVI is NTSC thus the option -r 23.967
This seems to generate an mpeg that is acceptable to vcdgear.
I haven't tested the result on my standalone player yet, because my cd-burner just died -
This is what I've been entering:
ffmpeg -i input.avi -b 1150 -sameq output.mpg
FFMPEG states it is using mpeg1 for video and mpeg layer 2 for audio, all of which seem reasonable. The resulting video has loads of artifacts in it and is quite jerky. BTW what version of FFMPEG are you using?
Regards,
Randolph Carter -
I've recently downloaded a ffmpeg cvs-snapshot (the current version wasn't available) so it is not much newer than 0.4.5.
Have you tried without the "-sameq" option ?
If I understand the options correctly then you first set the video bitrate to 1150 ( -b 1150 )
and than tell ffmpeg to use the same video quality as source (implies VBR) ( -sameq )
It is possible that these two options bit each other. -
I downloaded the CVS snapshot you mentioned, and everything seems to be working quite nicely now. The version I had previously did not support the -vcd option, I am not sure if this was a problem with how it was built on my system.
Regards,
Randolph Carter
ffmpeg output prores causes color shift
By liutszho in forum ffmpegX general discussionReplies: 1Last Post: 4th Jan 2012, 22:22 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
FFmpeg and quality of the output video
By Vidameker in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 20:46 -
Getting FFmpeg to use XviD codec with 4:3 instead of 1:1 pixel output?
By PBear in forum Video ConversionReplies: 7Last Post: 10th Jul 2008, 15:03 -
can FFMPEG output info from video?
By squadjot in forum Video ConversionReplies: 3Last Post: 13th Apr 2008, 18:32
