i have tried with every encoder i have fond but no one word!!!
what ami doing wrong?![]()
Most downloaded avi's will be divx format with mpeg3 audio (mp3). Assuming you want to convert to (S)VCD format this should be straightforward using TmpGenc (tho variable bitrate mp3's can cause problems with some Tmpgenc versions).
I suggest you start reading the Howto guides linked on the left of this page. If still stuck then come back and ask, but a lot more info is needed before any useful answers can be given.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Conver MKV to AVI with same size and quality. How ?
By SB4 in forum Video ConversionReplies: 1Last Post: 7th Aug 2010, 14:49 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
I want to conver a file to FLV format. with audio aac and video as mpeg4/h2
By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 02:45 -
Premiere Pro CS3 can it convert avi to mpeg3 ?
By DBenz in forum Video ConversionReplies: 3Last Post: 13th Apr 2008, 14:42
