Can someone suggest a capture card that can capture old VHS tapes and take still image snapshots in high resolution.
Thanks for your help.
There's quite alot of capture cards out there and you need one that can capture analogue input, and convert it to DV for storage on your hard disk. From there you can edit, etc and then output to the format of your choice. Most video editing software will allow output of stills, but can't really improve on the resolution you started with eg. VHS.
I'm using a Dazzle Hollywood external capture card to capture from my old analogue camcorder and a VCR. It does have its quirks, but generally does the job.
help with capturing from various analog devices
By TARfan in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2010, 12:36 -
Capturing audio from analog tape - use NR or no?
By sphinx99 in forum AudioReplies: 5Last Post: 6th Mar 2010, 23:47 -
going CRAZY: capturing with ATI HD 3600 (analog)
By nuzumaki in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2009, 18:24 -
Need some help capturing Analog video
By zagorski in forum Capturing and VCRReplies: 5Last Post: 10th Dec 2007, 20:27 -
capturing 1080i YPbPr analog video
By cast55 in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2007, 15:21
