  1. hi...
    i recently bought a set of VCDs (burned onto a cd-r) from someone on ebay, and with the discs, the seller included a note saying:
    "These VCD's have an encyripted code that if dubbed, the dubbed cds will only be playable for a short time. Then an invalid format will pop up, rendering them useless."
    is this possible? i checked the FAQs here at vcdhelp, and i saw nothing that proves this is possible.
    if this is real, is there any way to bypass this encryption code?
    thanks
    -justin-
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    Where I walk, I walk alone. Where I fight, I fight alone.
  3. ok, i see that's it is indeed possible. with this in mind, is there any way to burn this VCD and bypass the encryption? i was reading other forum posts and there seems to be quite the debate as to how to do this and if it is possible.
    thanks
    -j
