How long does this typically take??? It says there is 17hrs remaining???
Thanks to anyone that can enlighten this newbie....
Hey sugarmag,
I was just looking over your computers specs and with your current CPU I'm not surprised it's taking this long. There is a direct relationship to the amount of processor speed and the time it takes to encode. The faster the cpu the faster the encoding goes. So basically what you’re seeing is normal for your computer specs. A lot of other factors come into play such as the length of the file your trying to encode, the number of filters that have been applied, also the encoding method you choose, such as whether or not your using 1 pass or 2 pass VBR and the bit rate you selected.
Divx multipass encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2009, 12:31 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
DVD to DivX encoding?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 12:33 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
