  1. Im not getting audio and video synch with DVDx.....
    Any suggests?
    Thx
    Rui Fragoso
  2. i know this maybe a daft question m8 but have you ticked the little box that says Audio / video sync ???? just a thought
  3. Yes i did
    Thx
    Rui Fragoso
    Aug 2002
    Connecticut
    I get sync/audio skipping problems only on certain DVD programs - usually special features. When it happens I get an error message saying that the audio could track not be found and the output audio will be set to 0...or something like that.
    Thoughts anyone?
  5. I "check" the box for "audio/video synchronization" under "Settings--> Input settings" Form in DVDx 2.0 and it always had the video come out in sync with audio - apparently this checks sync issues as it rips and therefore slows down the ripping process and is not necessary in most cases but hey we want the audio be in sync. The default behavior is its NOT checked/necessary
  6. I´m from Portugal and i have a same kind of problem My problem is when i play the SVCD and i want to go fwd, he goes, but when i continuos play, i lost the audio/video syncronisation. The audio start firts and then the video. I try to change several options, mas the result it's allways the same. i mark the audio/sync in the input option but nothing...can anywhone give to aal of us with this problem a solution?
