    Aug 2002
    manchester
    im using win xp
    whats the easiest software to use with this card
    ta andy
  2. Most Canopus cards (DV Storm, DV Raptor, EZDV) come with their prop software; in your case, it should probably be RaptorEdit/RaptorVideo...
    You probably have some plugins for Premiere in the installation CD. That will allow you to use Premiere. But without that, I doubt. The cards I mentioned are not general purpose IEEE1394 cards, but DV-specific cards only, that 3rd party softwares won't work out of the box.
    But then, the canopus software is so user friendly, and powerful enough that it should do a good job for basic NLEs.
    Hope this helps.
