I'm having trouble trying to convert an m2v into a playable mpeg file. Can anyone help?
get windvd or powerdvd xp and should not have any problems playing it. even through media player.
Where I walk, I walk alone. Where I fight, I fight alone. -
I have WinDVD and it won't play it. What I want to do is convert the .m2v file into a .mpeg file.
then the file is somehow corruptOriginally Posted by neosakuraWhere I walk, I walk alone. Where I fight, I fight alone.
Powerdvd should be able to play the .m2v stream, or as was said, it is probably corrupt. An .m2v file is just the video stream of an mpeg file. If you want to turn into an mpeg without sound, just use mpeg tools in tmpgenc and multiplex it with no other files. I doubt this will solve your problem, but you'll have an mpeg file instead of the bare .m2v stream.
m2ts to m2v
By pcb in forum Video ConversionReplies: 6Last Post: 20th May 2010, 21:22 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 00:05 -
PAL in m2v?
By gameroftheuk in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2008, 22:38 -
Problem with .m2v
By KameronK in forum Video ConversionReplies: 2Last Post: 6th May 2008, 10:39
