Hi:
In the Video FAQ's for this site you can find this:
What if I just use the cut and merge tools from TMPGEnc and cut the movie from begining to end (no real cut) using "Select Type MPEG-1 VideoCD or SuperVCD". Will this method repair my mpeg file to make it VCD/SVCD compliant?How do I repair MPG?
If You can't burn the MPEG as a VCD or SVCD then try to fix it:
Using freeware tools:
Try to fix it by multiplex it with (S)VCD Settings with TMPGEnc, launch TMPGEnc and select File->MPEG Tools and select Simple Multiplex. Select Type MPEG-1 VideoCD or SuperVCD depending what you are creating, select your mpg as video and audio input and select out and hit Run to make a new working mpg file.
THX
8)
Rey
SSD tips-n-tricks?
By Moontrash in forum ComputerReplies: 1Last Post: 20th Dec 2011, 17:14 -
Repairing/converting mpeg with slow seek
By aslaksen in forum Video ConversionReplies: 2Last Post: 29th Jun 2011, 03:44 -
Panasonic Tips and Tricks
By zorankarapancev in forum DVD & Blu-ray RecordersReplies: 154Last Post: 5th Apr 2010, 21:28 -
Cant play DIVX 3 on XBOX360 any tricks ??
By draven1968 in forum Media Center PC / MediaCentersReplies: 1Last Post: 18th Jul 2008, 22:31 -
Tips and Tricks
By squallheart in forum Video ConversionReplies: 11Last Post: 9th May 2007, 13:50
