Hi,
I am coverting VHS tapes to eventual VCD/SVCD format. The VHS tapes were originally recorded in EP format (6 hrs per tape).
QUESTION 1: I first captured to AVI using Pinnacle Studio. The "best" default for capture quality sets the frame size to 320x240.
However, since the VCD output will have frame size of 352x240, should I not be caputuring at 352x240? What will happen if I convert a 320x240 AVI to 352x240 VCD?
QUESTION 2: Given the quality of my source video (VHS EP), would you recommend I output to VCD or SVCD?
Thanks in advance for your help.
keep it at 320x240 and add borders ..
encode a little of it in both svcd and vcd and see which you can stand the most -
i suggest scale it to the resolution you want with tmpegenc.
but i think it's no use to create a svcd from such resolution.
vcd should work fine. -
What I did when i backed up my copy of Speed from VHS to VCD was to capture
it with Virtualdub at 352x288, 25fps with 44khz stereo audio to a DivX AVI.
I used the Low Motion codec with the bit rate set at 3000 to produce the AVI file.
Then added the sharpen filter and framserved to the Panasonic Mpeg encoder v 2.30.
Then just cut the resulting MPG and burned to VCD with Nero.
Resulted in a lovely job
Waylander -
it'd be better to cap to huffyuv for the vid compression over DivX since you're gonna VCD them. You don't want to compress it unless you have drive space reasons. See the top guide under CAPTURE (look <-)
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
45
By inherindian in forum Newbie / General discussionsReplies: 7Last Post: 4th Mar 2009, 20:26 -
3 questions about VHS > DVD
By Salva Veritate in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2008, 14:05 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
