How do I convert a file recorded as an ATI proprietary ".VCR" filetype to either AVI or MPG??
THANKS!
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
aughhhhhhhhhh!
I spent a couple of hours looking for that page.
I've rarely had a video question that wasn't answered on this site.
THANKS for the help!! -
Mirror - thanks for the catch.
I looked back on my original posting and in fact this does help those that may have captured in the ati vcr format and need a quick conversion to mpeg2. But alas my diatribe on the potential of an increased quality of using the ati vcr codec to improve quality did not prove out.
But for those that are stuck with ati vcr captures which require a quick conversion to mpeg2 it is a feature of the mmc software that can hopefully help in a conversion to a more workable mpeg2 file. -
Or you can do as I did and remove Media Library,it's is utterly useless.
I capture directly to mpeg and avoid that .vcr rubbish. -
MOVIEGEEK - you have the right answer. But if for some reason somebody has captured in vcr format it's easy to convert to mpg.
Where did this page go, I need to know how to convert the .VCR file to MPEG-2
http://www.vcdhelp.com/forum/viewtopic.php?t=72462&highlight=ati+vcr+convert+format
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 06:59 -
.mov to any filetype quality is poor.
By bobvanluijt in forum ffmpegX general discussionReplies: 5Last Post: 1st Mar 2010, 11:37 -
- which Video Filetype has the 'best quality'?
By Entry in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2009, 15:40 -
Media Filetype Converter Download
By Azakir in forum Video ConversionReplies: 1Last Post: 30th Jun 2008, 01:57 -
How to Connect VCR to ATI 650
By jshapard in forum Capturing and VCRReplies: 0Last Post: 22nd Sep 2007, 11:18
