Just wondering if encoding an .avi in TMPGEnc as a SVCD DVD, when you choose your cd-r 80min (VCD/SVCD) the bar goes over 80mins.. But if I change the % of disk capacity to 99.99%, to fit, will this cut the end of the video? Or will it actually encode the entire video to fit on an 80min CDR?
Do I have to change any of the bitrate/file size also?
Video Info:
480X480 23.976fps 44100 Stereo 45min 16sec
thanks to all!
Hr
Yes, but extremely slightly. You won't notice it.
However, if you were to cut it to like 50%, I'm pretty sure you'll see a big degradation on the quality.
If it went over to say 135% and you change it to 99% you would see a cut in quality, like in scenes with alot of action
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
