I was wondering if it is possible to encode a vcd into a dvd format to help make the quality the best it can be, but yet burn it onto a vcd format so my stand alone dvd player can play it. I have a Sony DVP - S350 Player if that helps. Also..has anyone tried to make a vcd compatible with the Playstation 2 dvd player? If so..how did you do it?
You can capture an MPEG1 at 720x480 and a bitrate around 4000, but I doubt it very much if the sony will play it, I have done XSVCD at 704x480 at 6000 bitrate and only found 3 DVD players that will play it
daewoo 5800
Sampo 631CF
AKAI 760
Oh, it looks fantastic, but you are limited to players that can handle it. -
IF YOU ENCODE IN DVD FORMAT IT WONT BE A VCD, ITLL BE A MINI DVD AND YOU CAN ONLY FIT ABOUT 20-25 MINUTES ON A CDR/RW. A VCD WILL NOT GIVE YOU THE QUALITY OF A DVD NOT EVEN CLOSE.
YOU CAN CHACK YOUR DVD COMPATIBILITY HERE
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=427&Search=Search&#commentsWhere I walk, I walk alone. Where I fight, I fight alone.
Is there such a thing as a DVD Recorder with HDMI Input?
By the_importer in forum DVD RippingReplies: 10Last Post: 11th Aug 2013, 03:30 -
Is there such a thing as a reliable DVD Recorder?
By V Bot in forum DVD & Blu-ray RecordersReplies: 22Last Post: 25th Jul 2010, 13:29 -
Is there such a thing as a good DVD recorder?
By ibex333 in forum DVD & Blu-ray RecordersReplies: 95Last Post: 25th Oct 2008, 19:00 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 12:52 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 04:28
