i get a "cant create file" error with tmpgenc when i open my .mpg file..
tried increasing the priority of directshow on the environmental settings to no avail...
can anyone suggest anything?
out of space in your temp drive? Check TMPEGenc's environment setting and see which drive it is using for working space.
checked out the temp space and twas fine.. but just the same i changed the path and i still have the same problem...
Do you get the msg when you first try to open the .mpg file from tmpegenc OR when it starts to encode?
What kind of .mpg file is it? mpeg2 from DVDs? mpeg1 from VCDs?
Have you tried using the DVD2AVI to get the .d2v file in place of the .mpg first?
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Problem with burning DVDs on Power2g, "not a valid file" error, please help
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 7th May 2010, 19:19 -
Software Help: CRC Error "File Broken", But Video Still Plays and
By mike69 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2009, 10:15 -
Attempting to demux VOB gives pop-up "file error" window eight ti
By taa in forum ffmpegX general discussionReplies: 6Last Post: 31st Aug 2008, 02:02 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20
