Hi Guys ,
thanks for reading my Query....I really need some Serious HELP..as I dont know much about this...
I have been using Nero Burn 5.5 till now very very smoothly with my CD Writer HP 9140i ...and it worked excellently....
But Since past few weeks a NEW problem has Emerged while burning CD's...
I have atleast Spoiled 20-25 CD's ....the Problem is that as an when I start Burning my CD (Data,VCD,Multisession)....the BURN Process starts ...
Nero does the Initial Read Speed Test ---as usual
Later as It starts the Burn Process Immediately or after 1-2% of the Start of the Burning Process ...it Constanly Shows the Error....Buffer Under RUN ..Writing Failed..
I have tried all things friends and at last I m seeking your Help...
I also tried changing the Buffer Settings from "Automatic" to "Manual" value "64"(which is the Highest)...nothing has helped me..
Also the direct CD to CD copy feature fails in the above manner....
Hey you Experts please HELP
...Is there something wrong in my CD Writer...or is it the Software problem Only....
Please HELP
Best Regards,
Nityanand...
i think its a hard drive or bus problem. you should do one of those hard drive diagnostics to see if your drive is performing up to par. the ability of your hard drive to send info to the burner is very important in the burning process. even when you are doing 1:1 your hd is still the middle man. my best guess is that your hd is hanging due to having alot of applications open or being full to near capacity.
food folks and fun -
Check to see if DMA is still enabled for HD and reinstall drivers for cd burner.Nero has a cd-rom utility called "Nero CD Speed" it's in the Nero Toolkit folder.If none of that helps I have to agree with Musty_Hustla,it's probably your HD.
I solved my buffer underrun problems (in another burning software) by lowering the burn speed from 8x to 6x.
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28 -
Trying to get an OLD program to run on a "newer" pc....
By Noahtuck in forum ComputerReplies: 13Last Post: 8th Aug 2009, 09:38 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23
