My question is I am looking the most efficient, compressed pixel size (from NTSC format) to display a decent quality picture on a TV being played from a written CD/DVD?
I own a DVD burner and I would like to make the most efficient use of DVD+RW capacity by burning as much compressed video as possible on it, but yet display a good quality picture.
I hooked my satelite TV up through my ATI all in wonder 7500 card and started recording movies. I have been recording them at the highest quality (720x480). Now, I want to compress them down & fit as much as I effectively can on a DVD. (ie. I think my "Pearl Harbor" recording came out to be 10 or 11 gig.)
What tool(s) do you recommend for this compression? I have a program that came with my ATI card called "Video Studio" made by Ulead. And I use it for DV camera. Can I use it for compressing or do you recommend something else?
I also have recorded some cartoons and I would like display them like "chapters" on a DVD? What do you recommend to do this?
Thanks!
PR
Results 1 to 1 of 1
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 10:42 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Changing the pixel size of Xvid AVI, but nothing else
By seaders in forum Video ConversionReplies: 10Last Post: 28th Jun 2009, 06:32 -
Bad Pixel. What comes next?
By videobread in forum ComputerReplies: 5Last Post: 8th Mar 2008, 22:07 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 04:55
