hi i want to do anidentical conversion from say a divx to mpeg the problem is say on the master conversion its like got the black box at top and bottom (just like widescreen) when i convert it to mpeg it is full screen and the picture seems to be stretched and of lesser quality i am using tmpge i want a copy of the exact master could you please tell me where im goin wrong thanxs![]()
Check the settings button. On the second tab is a few options including Aspect Ratio & Center vs. Full Screen Options in a dropdown box. Try them for a few seconds to pick the one you like
Panasonic DMR-ES45VS, keep those discs a burnin' -
For your stretching problem... in the advance tab choose "source aspect ratio 1:1[VGA]" and for "video arrange method" choose one of the full screen [keep aspect ratio].
For your quality problem. The short answer is you CAN'T get the same quality as the DiVX because MPEG is a lossy compression. You can increase quality by increasing the bitrate but you'll never get identical quality as the original.
-LeeBear
I get jerky video and some identical frames
By DavidGGG in forum DVD RippingReplies: 1Last Post: 23rd Feb 2010, 10:51 -
Same dvds but not all play identical
By aliefjoker in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2008, 10:44 -
2 identical wording subtitles on the screen
By workman in forum SubtitleReplies: 4Last Post: 19th Jan 2008, 17:49 -
Why do i get 2 identical subtitles running over each other?????
By Arwen-Katie89 in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2007, 17:41 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 09:12
