i am trying to rip a dvd i have used smartripper to rip the videos and dvd2avi program to rip the audio i want on my movie and i am using pinnacle studios am i going about this the wrong way or just missing something
ps on pinnacle it looks like i could compress an avi but i don't know how to rip an avi from a dvd
thx for your advice
scott
Use TMPGEnc insted
It's the BEST quality Mpeg 1/2 encoder out there.
you can get a free version from http://www.tmpgenc.net
Also, If your looking to make the job a little more automated, you can use the free software on my site...... but hang out till the weekend and i relese v1.01 cos it works better and has a lot of bug fixes.
=8-)DVD to VCD made eazy
http://www.eazyvcd.tk -
thanks for the help also is there a way to put the whole movie on one cd instead of putting it on two to three cd's depending on the length of the movie?
thx
scott -
Sure, just make a non-compliant XVCD instead of a compliant VCD, reducing the bitrate till it all fits. Of course, compatibility might (or might not) be a problem, depending on your stand-alone player, not to mention degraded video quality is likely to be noticeably degraded.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Creating movie (mov) reference files with ffmpeg or ffmbc
By musicman in forum Video ConversionReplies: 3Last Post: 6th Jul 2012, 18:40 -
Creating iDVD Movie
By wimbly11 in forum MacReplies: 13Last Post: 10th Aug 2011, 10:25 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 16:00 -
creating a dvd using idvd 5 of a movie around 3 hrs?
By tab75-13 in forum MacReplies: 2Last Post: 1st Jun 2007, 06:12 -
Creating Movie
By Adarsh2211 in forum Video ConversionReplies: 2Last Post: 28th May 2007, 22:42
