I have a Masonic dvd-xv10 home player,which plays.dvd/vcd/cd-wr/photo cd/mp3/cd.
problem ,on a couple of vcds (that work ok on other dvd machines)
the picture and sound quality are very good ,but it stops and stars very fast(at the blink of an eye speed) like hickups and if I speed up the play
picture is fine but sound is out of sync,and as I said on other dvd players including pc everything is ok.
If these are VCD's you made yourself, next time I suggest you try a Demux and then a Remux of the mpeg file before you burn to CD. I had the exact same problem with my Apex AD-1500 once I started doing the Demux and then a Remux (I'm using TMPGEnc for the Demux/Remux) I no longer had the problem.
hwoodwar
Would you mind elaborating on (Demux/Remux/TMPGENC,not well into this jargon
and I didn't check my spelling I should have said
PANASONIC..not masonic
cheers AL*D
Sound hiccups in DVD-lab slide show
By seajeep in forum Authoring (DVD)Replies: 0Last Post: 13th Oct 2011, 11:04 -
AVCHD thru Premiere CS4 encodes hiccups in audio
By ddane in forum Video ConversionReplies: 5Last Post: 11th Dec 2009, 17:21 -
Video Music Clips with Hiccups
By zenzen1 in forum Software PlayingReplies: 4Last Post: 23rd Aug 2008, 23:09 -
Audio gaps/glitches/hiccups when importing long play DV footage
By teraldlarwood in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 12th Apr 2008, 08:34 -
Motion graphics have the hiccups - can I improve?
By Ivor Bigone in forum MacReplies: 2Last Post: 13th Feb 2008, 09:47
