I am recording an avi file from a VHS recorder & it records but when I play it back, the picture gets stuck on one frame & the sound continues.
I am using a rage fury pro vido capture card.
Can any one assist with my problem.![]()
Canu
Macrovision
If your VHS is not protected then you are using an ATI and you VHS is old and the ATI is detecting the poor signal quality as macrovosion ( tells you something about macrovosion ). -
Did you drop frames while your were capturing ?, you may have a corrupt file. Load the AVI into Vdub and scan for junk frames.Originally Posted by Canu
Need help recording from VHS>DVD, also MKV> AVI/MP4, w/subs
By Condor Joe in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2011, 19:37 -
Problem recording onto VHS from AV2 - but DVD works normally - help please!
By Sassie in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Jan 2010, 08:15 -
VHS to DVD with AVI/WMV recording?
By Jorabi in forum DVD & Blu-ray RecordersReplies: 14Last Post: 14th Nov 2008, 15:48 -
AVI file won't play back
By Clydesdale in forum Software PlayingReplies: 9Last Post: 4th Apr 2008, 00:22 -
VHS to DVD recording problem - strange line only shows up when viewed on PC
By CodySave in forum DVD & Blu-ray RecordersReplies: 11Last Post: 16th Jul 2007, 03:09
