i've been trying for days to get this right but i can't i've tried diffrent encoders and still the same problem i can't figure it out i've posted a couple message's and no one even looked at them could someone please help me before i go nuts i'm using dvd2svcd i've used all the setting it recomends to use in the newbie guide on doom9 and i'm getting out of sync audio every time i've done about three movies all the same thing i've used tmpg and cce both the same problem i will post my log file so you can see if anything there is wrong all the help would be greatly apreiciated (help if i could spell)here's my log file
Key found: D74832D581
- 8/27/02 4:19:50 AM
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.0.9 build 3
Initializing
Initializing finished.
- 8/27/02 4:19:53 AM
- Free on drive C: 12238.77 mb
- Internal rip
Preparing vobfiles to be ripped:
- G:\VIDEO_TS\VTS_01_1.vob
- G:\VIDEO_TS\VTS_01_2.vob
- G:\VIDEO_TS\VTS_01_3.vob
- G:\VIDEO_TS\VTS_01_4.vob
Ripping: G:\VIDEO_TS\VTS_01_1.vob
Ripping: G:\VIDEO_TS\VTS_01_2.vob
Ripping: G:\VIDEO_TS\VTS_01_3.vob
Ripping: G:\VIDEO_TS\VTS_01_4.vob
Ripping finished. Speed: 6630
- 8/27/02 4:29:15 AM
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\Program Files\DVD2SVCD\Movie\VTS_01_1.vob,C:\Program Files\DVD2SVCD\Movie\VTS_01_2.vob,C:\Program Files\DVD2SVCD\Movie\VTS_01_3.vob,C:\Program Files\DVD2SVCD\Movie\VTS_01_4.vob]
Analyzing DVD2AVI Project file
Force Film activated!
Framerate: 23976
DVD2AVI processing done.
- 8/27/02 4:34:13 AM
- Free on drive C: 8597.97 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Audio extraction finished.
- 8/27/02 4:45:08 AM
- Free on drive C: 8464.90 mb
- AUDIO conversion
Converting Audio to MP2. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -g max ) -2lame( -e -b 128 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 8/27/02 5:04:41 AM
- Free on drive C: 8370.84 mb
- Converting Pictures
Converting: C:\Program Files\DVD2SVCD\DefaultTitlepicture.bmp
Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 8/27/02 5:04:49 AM
- Free on drive C: 8369.85 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1665085576
AudioSectors: 100057496
VideoPAPO: 24243120
ScanOffsetBytes: 177319
SeqAligningBytes: 11269620
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 600.00
PureMPEGStream: 1529338012.53
Seconds: 6170.08
CalcMPEGStream: 1529338012.53
Frames: 147766
CDSize: 800.00
Cut point 795.00
Variable Settings:
Frames: 147766
Anti Noise Filter: 2
Passes: 4
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 1982
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1 .DLL")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2DEC\MPEG2DEC .DLL")
mpeg2source("C:\PROGRA~1\DVD2SVCD\MOVIE\DVD2AV~1.D 2V")
SimpleResize(480,480)
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 0.740
Video Encoding finished.
- 8/27/02 4:51:40 PM
- Free on drive C: 6709.38 mb
- Video Pulldown
Executing Pulldown. Commandline:
"C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\Program Files\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC.mpv" "C:\Program Files\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.m pv"
Video pulldown finished.
- 8/27/02 5:11:28 PM
- Free on drive C: 5421.21 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\TitlePicture.bmp.mpg"
- 8/27/02 5:11:39 PM
- Free on drive C: 5417.16 mb
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg"
- 8/27/02 5:11:42 PM
- Free on drive C: 5417.11 mb
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mb
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
3090 Seconds
Offset in Seconds: 3092
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
Multiplexing and cutting finished.
- 8/27/02 5:46:40 PM
- Free on drive C: 3830.02 mb
- Determining length of audio
Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
3092.787 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
3070.800 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
Analyzing finished.
- 8/27/02 5:48:47 PM
- Free on drive C: 3834.02 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 17
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\Program Files\DVD2SVCD\Movie\CD_Image_File_CD1.cue" --bin-file="C:\Program Files\DVD2SVCD\Movie\CD_Image_File_CD1.bin" "C:\Program Files\DVD2SVCD\Movie\VCDXBuild_Script_1.xml"
- 8/27/02 5:53:14 PM
- Free on drive C: 3023.72 mb
- No. of chapters to create: 12
CD image #2: CD_Image_File_CD2.bin
"C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\Program Files\DVD2SVCD\Movie\CD_Image_File_CD2.cue" --bin-file="C:\Program Files\DVD2SVCD\Movie\CD_Image_File_CD2.bin" "C:\Program Files\DVD2SVCD\Movie\VCDXBuild_Script_2.xml"
CD-Image creation finished.
- 8/27/02 5:57:36 PM
- Free on drive C: 2220.55 mb
- SVCD Creation finished!
- 8/28/02 1:51:17 AM
Initializing
- 8/28/02 1:51:18 AM
- Free on drive C: 2184.56 mb
- Crash Recovery
- Restarting from: Finalize
- 8/28/02 1:51:19 AM
For usefull help, you might want to clarify whether your encoded / muxed .mpg file itself, when viewed in Media Player for eg, is already out of synch. From your post, it is not obvious whether to preclude burning software issues that many other posters have expressed, for eg with Nero.
