Hi,
I'm in the process of ripping my first DVD (Traffic for curiositys sake), and i'm not sure everything is going smoothly. Its been going for 4.5 hours. I'm using DVD2SVCD (version 1.0.9 build 3) w/ CCE (version 2.64.01.09).
I'm running a new Pentium 4 w/ a 2ghz chip + 256mb ram (how long should it take to rip + encode a dvd on average?).
CCE has been at it for around 4 hours (it completed some task and is now on some other task). It is currently encoding 'Encoded_Video_CCE_PAL.mpv' and is 15% done. It is reporting that there is 8 hours 30 mins left. The file is already 1.25 GB (1,347,158,016 bytes) big. It seems strange that the file is that big.
My question is: is this normal? I don't really wanna wait over 8 hours for something that doesn't work
Cheers in advance!
Depends on your dvd2svcdsettings, cce settings and used Avisynth filters.
Probably it is OK.
http://forum.doom9.org/showthread.php?s=b7d43e8cb27ae608de0209f30326ee93&threadid=21859 -
On my PIII 850Mhz, it takes on average from start to finish about 16 hours using DVD2SVCD and CCE 2.5SP. But the quality is worth the wait
Panther
All say Grrrrrrrrrr......................
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 12:10 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 14:09 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
