I'm sorry if this is a stupid question but I am new to the world of VCDs.
I recently purchased some vcds from an asian store and they work fine on both of my dvd players and my computer.A friend in the Philippines sent me some burned copies of vcds from there and they don't work on the dvd players or the computer.I'm not sure what format they are.Is anyone out there familiar with this problem?I've thought about buying a couple of vcd players when I go back there but I'm not sure if I would have to get a converter for them to work here.I was also told that the players sold there are very cheaply made and poor quality.I guess I'm wanting to know if the vcds from the Philippines can be converted into a format that will play in my dvd player?If so what program would do this.
Thanks in advance,
Tattoo
Tattoo,
Check if:
1) the VCDs were burned according to the correct VCD format specifications
2) the contents of the burnt VCDs were in their proper DAT files and not MPG files.
You can use the program VCD Gear to check and correct if the DAT files were corrupted. You can use NERO to burn the corrected MPG file into VCD format.
Availability of multi region dvd player in the Philippines
By loster in forum Newbie / General discussionsReplies: 4Last Post: 8th Jul 2011, 12:58 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
