I transferred a show from my VCR to my computer and there is this constant buzzing noise in the background. Is there a way to get rid of that using TMPGEnc? Or is there another program for doing that?
Thanks!
Try to find out what is causing the buzz, sounds like a faulty lead. Not screened properly, also try adjusting audio controls on capture.
You may be able to remove the buzz with www.goldwave.com (WAV)
Reducing/eliminating scan lines?
By Captain Satellite in forum Video ConversionReplies: 9Last Post: 23rd Nov 2011, 06:37 -
Eliminating VHS flaws.
By FreddieP in forum Capturing and VCRReplies: 21Last Post: 21st Jul 2010, 18:33 -
help with eliminating Interferences (Video Noise) using S-Video
By F07 in forum Capturing and VCRReplies: 2Last Post: 2nd Sep 2008, 16:25 -
Eliminating 1 audio track
By Mark-Leon in forum ffmpegX general discussionReplies: 3Last Post: 6th Aug 2008, 18:44 -
Filtering Buzzing Noise from Audio
By Tchail in forum RestorationReplies: 4Last Post: 12th Sep 2007, 23:49
