how can i bring my ac3 or dolby pro tools mixed audio to dvd? do i save it into data wav or aiff, sound amnager and what?????
thanks
all depends on what software you use. Some of the consumer level DVD editors don't like dolby digital...or only support 2ch DD. Spruce Up will accept 5.1 ac3 files...not sure about Studio 8....other than that you start getting into the pro level software, Reel DVD, Maestro, Impression, and Scenarist all do 5.1 ac3 but you are looking at big $$$
Assuming i was to use any of the pro level dvd software, is it correct to save the pro tools mixed 5.1 and ac3 to data and would be recognized by reeldvde, scenarist or what have you softwares
thanks
Convert BD audio from DTS-HD to Dolby 5.1 AC3 without video?
By agent154 in forum AudioReplies: 1Last Post: 5th Apr 2012, 17:19 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
trying to convert avi w/ dolby ac3 audio and it wont sync right
By cduval04 in forum Video ConversionReplies: 2Last Post: 14th Jan 2009, 18:40 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 14:30 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
