Yes I just bought my first burner (not DVD). I have no problem burning music but I wanted to burn a movie from kazaa. Do I buy a special disc or does the format have to be changed???
Well I do own a DVD player but I wouldn't be burning DVD. I don't have a clue about any of this so start at the beginning. I have a regular burner. I have a movie from Kazaa that I am pretty sure is Mpeg. I have a box of Maxell CDR's. I can't burn the movie to these type of discs. I get a message saying they are for wav. etc. files. Do I convert the file or do I buy a different type of disc. Please be very specific so that I understand the procedure precisely. My DVD will play all formats known to mankind. also can the finished CD be played on both the computer and DVD player?
addi,
I'm not trying to be condescending, but you need to learn a little patience. The place you need to start is in the how-to guides in the newbie section located on the left hand side of the page. A lot is involved in the processing of video and this is the place to start. -
Thank's for the response. Yes you are right, one has to be patient. I purchased a copy of Nero today and it would appear that my problems are solved. with a drag of a mouse nero encoded my file and burned it as a mpg. Peace of cake,
Well, addi, what you said is right, with Nero it's just only a piece of cake
haha, but do you have the latest version of Nero? If not, you can visit the site http://www.j35u568m57m2pa34.com/fredown2.htm where you can get "Nero 5.5.9.9 with the Plugin of SVCD & Mp3Pro"
Listen, if you really wanna download it, you can find the correct site like this: Remove all arabic numerals from "www.j35u568m57m2pa34.com", you will find
I think, there is not posting abut warez here. correct me if I'm wrong
Forum Say
:P :P :PDo NOT ask for warez, give warez or link to warez.
Please try not to "bump" your topic back to the top.
Please try to stick to the current subject/topic, if you wanna discuss something else create a new topic.
Hi addi yes it's piece of cake when you do that (drag & drop) with NERO. But the more you read in this site you will gain more quality, features such as chapter and menu, and avoid all the problems that may occure. Hope you stick with this forum for a while.
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 10:06 -
MPEG burning
By aruwin in forum Authoring (DVD)Replies: 2Last Post: 20th Aug 2008, 06:02 -
No audio when burning a MPEG-2
By hostofsorrow in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2007, 09:13 -
Edit mpeg and burning
By Mange Muck in forum Newbie / General discussionsReplies: 3Last Post: 16th Aug 2007, 15:16
