how do i do it??? read the how-to's but i couldnt find anything.. do i have to convert to mpg first?
Did you perhaps miss http://www.vcdhelp.com/avi2divx.htm ? It's pretty well explains itself.
You must be new here. Try to think of .mpg as a different world from .avi.
It's like a totally different compression, and has nothing to do with .avi.
Remember Divx and Huffy are compressions in itself that's used under an .avi umbrella.(Huffy really isn't for playback but rather capturing, and Divx is great for playback, but shouldn't be used for capturing).
That being said, you also have to ask yourself "What do I want in the end, and what do I have to work with". You'll save lots of hours of searching an learning the hard way. -
First off no you don't need to convert to mpeg format first. The tool of choice to do the conversion would be VirtualDub of which I'm sure most people in this forum would agree. To be honest the best place to look for the information you want is over at DivX.com in their how to section. Just follow this link: http://www.divx.com/support/guides/index.php
I hope this helps.
Converting Divx to AVI with a Twist
By Deathbot70 in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 13:42 -
How to retain 16:9 when converting to Huffyuv?
By brassplyer in forum EditingReplies: 3Last Post: 25th Apr 2010, 08:15 -
Converting a Home DVD to AVI - but not divx?
By sterankin in forum Video ConversionReplies: 4Last Post: 16th Feb 2008, 12:52 -
Converting ISO to AVI (Divx or Xvid)
By cyberjackal in forum Video ConversionReplies: 2Last Post: 11th Jul 2007, 11:50
