Can it be done ?
Can I extract a audio track from a mpg and repair it (remove hiss,ect..) and then put it back in again. ?
The audio repair I can handel, I'll do it with cool edit. I just need some direction on getting it out and then back in again.
Thanks.
In Tmpgenc under file select Mpeg tools. Simple demultiplex with separate the two streams, simple multiplex will put them back together. Other programs will do it as well, the term you're looking for is multiplex and demultiplex.
Thanks !
That did the trick.
One more thing. You wouldn't know how to convert a mp2 to wave and back again. ? Cool edit dosent seem to like mp2 files. Goldwave will process the file then convert it to a wave file, but I haven't figured how to get it back to mp2 again.
Thanks again.
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
Need help repairing clipped (distorted) audio
By headless chicken in forum AudioReplies: 6Last Post: 20th Apr 2010, 17:00 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 19:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
