I am trying to burn a cd using nero - I am using nero and have successfully burned one movie, but nero keeps freezing when trying to burn another. The only difference I can see is that the one that worked had "dvd-ripped" in the title and properties show it as a mpeg/video/audio stream, the other movies that I am having problems with show properties as "microsoft video/avi ", I have tried reinstalling nero, using different makes of blank cd's and tried several different downloaed movies.
I have decompressed it and when I try to recompress as a MPG it also freezes - my friend just downloads any movies and burns straight to disc!!! can any one help please.
Nicola J...
AMD XP1800
Nvidia Geoforce 2
512mb ram
80gb hard drive
32 cd rom
30x cdw (i think!!!)
Be More Specific.......
Are you trying to burn them as a Video CD?
- If you are, then thats your problem. VCD's need to be a special type of MPEG file (NOT AVI). Nero will try to convert it for you, and this may be what you think it is freezing, as it takes a long time.
Are you Burning then as a Data CD?
- If you are, then it should work.DVD to VCD made eazy
http://www.eazyvcd.tk
How do I burn .avi using Imgburn?
By rocky12 in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 04:20 -
How to burn avi with subs onto a CD?
By Meagain in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2009, 17:40 -
AVI to DVD burn?
By tim_ver in forum DVD RippingReplies: 3Last Post: 17th Jul 2007, 06:04 -
Burn AVI movie.
By mutras in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2007, 20:19 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
