How long does it usually take TMPGEnc to encode a dvd? Cause mine has been encoding for over four hours now.
just a suggestion but nobody will answer unless you give specifics. ie. whats the source if its a 20 gig avi thats one thing or a 2 gigmpeg 2? i find my avi's from the internet take about an hour maybe for an hour and a half movie! thats approx.
The time TMPG takes to decode depends on if you're encoding to MPEG1 or MPEG2. MPEG2 will take much longer. Also any resizing and filters you add will increase the time. For a straight standard VCD with no filters or anything it'll probably take an hour for a 90 minute movie. For a multi-pass VBR SVCD, with a bunch of filters over 20 hours is not uncommon.
-LeeBear
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
How to encode using TMPGEnc Xpress to 264?
By klas in forum Video ConversionReplies: 1Last Post: 8th Jul 2008, 04:13 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52 -
Auto encode AVI's and DVD TS_FOLDER's to 10min long FLV files
By patrean in forum Video ConversionReplies: 0Last Post: 6th Jul 2007, 10:36
