I have been capturing MPEG2 with my AIW7500. Sometimes my computer freezes in the middle of the capture, and I have to restart. The file that I have, be it 200 MB or 5 GB won't play.
When I click on this "interrupted capture" the file player says 0:00 under the "time" and nothing happens.
Is there a way for me to repair or otherwise correct these so I can just pick up where I left off, instead of starting from scratch?
HELP!
Andy![]()
Use the mpeg tools in TMPEGnc or whatever application your using and try de-mulitplexing and then re-mutiplexing the file. More than likely it's the file header that's corrupted and this should correct it. It's worth a try anyhow.
i did this, and at the end of the process
(i used the 'de-multiplex" tab, choosing the video and then the audio, giving me an m2v and an mp2 file. Then, I used the multiplex to combine them into an mpeg2 file again.)
After it finished, it said "packet 30... blah blah, there may be playback error"
I played it and it played perfectly. If I want to merge these files later will it be okay? I'm not sure what the warning meant...
THANKS FOR THE SOLUTION THOUGH - I'M F*ING ECSTATIC!!
Andy
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Interrupted WinDV Capture...Now I can't play the AVI file.
By ione in forum Capturing and VCRReplies: 11Last Post: 18th Oct 2009, 09:52 -
Fixing Sandisk V-Mate's MP4 files when interrupted
By Atario in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 20:50 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24
