Are there any important differencies between CCE's 2.50 and 2.64? I mean on level of picture quality and/or speed processing.
Results 1 to 10 of 10
I'm not sure but I don't think that CCE 2.50 can use 5 pass VBR. Also when I used 2.50 to export from Adobe Premiere one of my movies, in the middle of the movie i got some broken frames. Same movie with 2.64 was encoded perfectly !
You can do 5 passes with CCE 2.5 SP.
@Arian - the reason that everyone on this board uses CCE 2.5 is because 2.64 won't allow frameserving-if you don't know what frameserving is, read one of the guides to the left there, but suffice to say it is one of the MOST useful tools when converting video.
Try VDub at first, then you can graduate to AVISynth...End of Line. -
I’m already using Avisynth. And I’m really impressed from it!
I have some problems using MPEGDecoder.dll. Frameserving from vobs to CCE 2.50 looks to work all right, but a little wile before the end of the movie, CCE (CBR mode) stacks! I don’t know yet if this is an MPEGDecoder.dll problem or I have write something wrong on my script. I must make some more tests to decide
MPEGDecoder.dll is still under development and somewhat unstable. At the moment I recommend to use the good old DVD2AVI / MPEG2DEC.dll method.
CCESP 2.64.01.09 or newer reads Avisynth scripts. -
Since I'm new on that stuff, your good old method is a little bit unknown to me!Originally Posted by Truman
Can you please point me to a guide describe this method?
2.64.01.09 and above (2.64.01.10 is on their site now) will load *.avs files. I don't know how you upgrade from 2.64.01.01, though.
Xesdeeni -
guide:
http://www.doom9.org/mpg/d2a-mpeg2dec.htm
download ccesp 2.64.01.10 trial
http://www.cinemacraft.com -
Thank you!Originally Posted by Truman
Got it allreadyOriginally Posted by Truman
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 15:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
