hi,
today, I just ripped Austin Powers 3: Goldmember. I followed a guide that was on a cd that I have.
The programs that I used were:
DivX Codec (3.2)
DVD Decrypter (2.4)
FlasK MPEG (0.594)
DVTool (0.24b)
PX3s AC3 -> WAV Converter (0.4b)
VirtualDub (1.4c)
It was my first rip from a DVD that I have ever done and when I finally got it on my pc, it was 526,598kb and when it was on the DVD it was 3.7gb. I am also knew to DVD ripping and when I tested it out it worked fine. I then put it onto a CD and tried it on my brothers computer and my dads computer but it didn't work on either of them. When I tried it on my brothers and dads computers I tried playing it on Windows Media Player but when I clicked on the play button it comes up with: "An invalid media type was specified". I also thought I saw something about "Codec" when it was trying to load up. Now, when I came up to a part where I had to choose which video codec I wanted to use I had to install "DivX Codec (3.2)" on my pc and choose that. However when I had to choose which video code I wanted to use on FlasK MPEG I could choose "DivX ;-0] MPEG-4 Low-Motion" or "DivX ;-0] MPEG-4 Fast-Motion". But on the guide it said to pick DivX MPEG-4 Video Codec but it wasn't on the list so I picked DivX ;-0] MPEG-4 Fast-Motion.
Now, I could be wrong but I thought that it might not be working on my brothers and dads pc because the codec that I installed on my pc isn't on there pc. But I would like it so it works on every pc fine without installing any video codecs.
If there is anyone that knows that something that I can do to make it work or anything I can download and change. Please tell me.
thanks alot,
Jonathan Cooper
First things First, you asking in the wrong forum, but i'll be nice and answer you question.
Install the DivX Codec on the other computers that you wish to play the movie on, and it will wiork fine.DVD to VCD made eazy
http://www.eazyvcd.tk -
yeah, I thought of that idea but if I did that i'd have to give the codec to everyone else to install it on their pc. I was wondering if there was a codec that I could use so that everyone else has it and doesn't have to install it on their pc and it will work.
thanks,
Jonathan Cooper -
The codec is actually fairly small. You can just burn it to the CD and they can install it in a jiffy - also include a readme.txt file that explains it.Originally Posted by supercoop
Yep, MPEG-1 video is the best bet for that.I was wondering if there was a codec that I could use so that everyone else has it and doesn't have to install it on their pc and it will work.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
thanks alot for the help, have you got MPEG-1 video if so please could you send me it to: john@coop58.freeserve.co.uk
If not please could you give me a link to where I can get it from.
thanks,
Jonathan Cooper -
MPEG-1 :S all windows pc can play MPEG-1 it comes with the OS
if you want to play a VCD on a PC just go to the Folder on the VCD named MPEG_AV
in there you will see a file with the extention .dat
open this file in Windows Media Player
Oh, and if you want to make your DivX playable without installing the codec, use the version v3.11 codec as it is just a hack of Micro$oft's Mpeg 4 codec. (I never liked DivX 4->)DVD to VCD made eazy
I can't see MPEG-1 under the codecs on FlasK MPEG. The codecs that I can choose from are:
Cinepak Codec by Radius
Intel 4:2:0 Video V2.50
Intel Indeo Video 4.5
Microsoft RLE
Microsoft Video 1
Microsoft H.263 Video Codec
Microsoft H.261 Video Codec
Indeo video 5.10
DivX ;- MPEG-4 Low-Motion
DivX ;- MPEG-4 Fast-Motion
Full Frames (uncompressed)
will all of those above come with every computer as standard apart from DivX ;- MPEG-4 Low-Motion and DivX ;- MPEG-4 Fast-Motion because I installed those myself. If so, which one will be the best to use and that everyone will have on their computer.
thanks,
Jonathan Cooper -
Just use TMPGEnc to convert to MPEG-1.
If a DVD/CD will only play on the computer...
By LellyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2010, 08:38 -
One specific ripped DVD folder does not play in Windows Media Player
By aslaksen in forum Software PlayingReplies: 2Last Post: 11th Apr 2010, 19:16 -
can ripped BD play on PS3?
By fkw81 in forum Blu-ray RippingReplies: 1Last Post: 16th Mar 2009, 04:08 -
problem getting ripped dvd to play in my standalone
By rmb3 in forum DVD RippingReplies: 7Last Post: 25th Jul 2008, 05:16 -
How do you play your ripped DVDs?
By andy99 in forum Software PlayingReplies: 12Last Post: 6th Dec 2007, 02:39
