I have AVI_IO trial installed (non-cracked) and huffyuv 2.11 too. When I want to select compression, AVI_IO does not detect huffyuv.
btw, Virtual Dub detect it, so I assume huffyuv is installed properly.
Any suggestions please?
Is anyone here, who captures with AVI_IO using the huffyuv codec successfully? btw, I'm running WinME.
Hay Truman,
Stupid question, did you reinstall huffy again?
yeah, I have used avi_o and huffy with no problems.
...(not using it at the moment though!)
win 98 -
Everything works fine. I was a fool, forgot to set the format to yuy2. Sorry for waste your time.
Which codec
By Tafflad in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 19:58 -
Which codec?
By Andyncu in forum Video Streaming DownloadingReplies: 5Last Post: 13th Feb 2011, 08:11 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
