Results 1 to 9 of 9
  1. Ok, this is what happened.
    everything was working fine.
    then I tried to install some kind of WinTV thing from the "add programs" list in the control panel, but when I rebooted the new program was nowhere to be found
    but I noticed that the "speaker" icon was gone from my tray at the bottom.
    so I downloaded the sovl32.ex(or whatever it is) and when I downloaded it, I could no longer see anything on the MMC7.1
    I tried to uninstall ALL my ATI stuff, and even got rid of the solv32.exe file and STILL is black
    I can't see what might have installed when I tried to instal that wintv thing..
    help!!! someone!!!
    thanks
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    really honestly a re-install of windows is sometimes the best method for "weird crap that happens"
  3. I'm not in a position to reinstall windows because I don't have a windows disc...
    there MUST be some kind of conflict or some kind of setting adjustment I can do!
    anyone know??
  4. well, you can restore your previous registry, but need to know what OS you are using
  5. I have windows ME
    I tried to restore my system to an earlier date but I got a "stmgr has caused an error in wintrust.dll stmgr will now close" I can still access the system restore screen but when it reboots it says "unable to restore"
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    honestly --- buy a windows cd and dump ME ASAP ..... even if you have to use 98se instead of ME
  7. i restored the registry and got the speaker icon back on the task bar but still get that black screen with mmc
    Jul 2002
    Erie, PA United States
    Try this......uninstall all the ATI Software including your display driver and do a clean boot. Re-install DirectX 8.1 and reboot. Reinstall your display driver as normal and proceed to reinstall MMC. If this doesn't work and since you've already done a system restore, I don't see where you have a choice but to do a clean install of your OS.
  9. well after uninstalling and reinstalling everything about 4 times AND going into the control panel and deleting a bunch of mysterious device controlers I got the thing back up and runnin!!!!!! 8)
    I have no idea what combination of what did it, but something did it for me!
    thanks for the tips guys! 8)
