I have installed the Huffy but it doesn't show in VitualDUB menu options. It shows in other programs but not in V DUB.
If anyone have any idea please.
Damir
Yes, I have. Everything stays same. If i open IU-VCR there is option to pick Huffy but not in Virtual Dub. btw I have WinTV
Ahh..
If you are capturing Huffyuv will only appear if your video capture format is compatible..
UYUV, YUY2, RGB and some others are compatible.
Cheers
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 14:56 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 22:01 -
huffy -> xvid
By geonuine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 3rd Nov 2008, 08:49 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
Problem exporting a file with HUFFY UV
By V.A.M in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 19:53
