Guys, does Maestro work on Win98SE ? I can seem to load it up in both my computers. It says i cannot be runned on a win95 or win3.1. But i'm not using those files. Darn ! Need maestro to run to finish up on my DVD9-DVD9, Please help me out. Thanks.
WIN98SE was built on the WIN95 core, so if it says that it won't run on WIN95, then it won't run on WIN98, either.
If you are going to do this a lot, then I would recommend an OS change, and choose one that can handle NTFS file systems. -
Then i would seriusly have a problem as my DVC2 card doesn't support WINXP yet. Sigh, any suggestions on other programs i can use to create .vob files and just insert them into the IFO files later ?
Different installation problem
By dmf in forum ffmpegX general discussionReplies: 9Last Post: 11th Jan 2012, 15:02 -
I have some problem with wvc1dmo installation.
By Dboyz in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2009, 03:23 -
FLVtool2 installation problem
By linea in forum ffmpegX general discussionReplies: 34Last Post: 15th Dec 2008, 12:09 -
Problem with the installation!
By defacta in forum ffmpegX general discussionReplies: 3Last Post: 19th Jul 2007, 23:37 -
By gokes in forum ffmpegX general discussionReplies: 1Last Post: 10th Jun 2007, 03:55
