I was wondering if any type software exists, or is there a way to fix this in maestro or any other authoring program, thanks
Results 1 to 11 of 11
Not that I know of.
Having posted this question b4 on other forums, I got the same response as you.
Invariably, for me, DTS is always asynch compared to 5.1 when I author in Maestro, so I go for the 5.1 -
You could always edit the .m2v file and cut or add a couple of frames at the beginning of the movie. An NTSC movie at 24 fps will show each frame for approx. 42ms. Adding or removing a couple of frames should help sync the movie.
Hey , thanks for the reply, enemy, what would be the easiest way of adding or deleting a frame or 2 ? sounds like this might work.
thanks, i'll give it a try. one more thing, do you know of any other ripper besides smartripper that extracts dts ?
if you need to delay the audio stream .. Maestro can do this easy -- just bump the audio stream forward .... you can start the (audio) stream anywhere on the movie line ..
you can lock track assets after that if you wish ... sometimes not a good idea . -
THE RIPPER Posted: Aug 29 12:04 Post subject:
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
Software that can output to MKV with 1920x1080 and DTS Audio
By mady3650 in forum Newbie / General discussionsReplies: 3Last Post: 27th Nov 2010, 14:05 -
Color Corrector
By cynikalhedonist in forum EditingReplies: 8Last Post: 25th Jun 2010, 12:49 -
Hardware corrector or Software
By mark23 in forum RestorationReplies: 4Last Post: 11th May 2010, 03:43
